Hi
Apologies if this is covered elsewhere - I have done a search and found the below tip - I tried this but it did not do the job.
My keys are working, and when used manually in the door lock they centrally unlock and lock the car OK. When I remotely zap the car from a distance they adjust the mirrors, seats, etc but they are not locking / unlocking the car. When the car is running the central locking button is also not functioning (but the central locking functions fine with the keys manually).
I have just done a cooling system fix during which I disconnected the battery.
Any help much apprecaited.
Paul
What I tried which does not seem to work-
"holmesy wrote:
Hi Gazellio
Hope this helps.....
Programming a new Key
Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize."
Paul
"holmesy wrote:
Hi Gazellio
