Hello my esteemed Range Rover connoisseurs,
I come to you seeking your Range Rover guidance. I have a 2000 4.6 HSE. I bought it used and the dealer told me the windows, moonroof, and mirrors' controls didnt respond.
these are all the elements on the Center Console Switch Pack. I looked through this site's p38A forum and found that this problem often occurs because the switch pack is "dirty" or dead. (I do NOT know how this problem came to be. The dealer said that it only occurred recently as the truck had been on the lot for a few weeks.)
I took the switch pack out and cleaned it, although it wasnt really that dirty, and put it back in today but it didnt fix my problem. The fuses are all fine as well (1, 9, 22 et al).
This is what does and doesnt work:
None of the windows open whether I use the buttons on the center console switch pack or the switches on the rear doors.
-----Leads me to assume wiring harness?
The center console switch pack's LIGHT lights up when i turn on my head lamps.
-----Dont really know what to make of this except that the BECM is distributing power to the switch pack.
The truck's message center says that the Sunroof is Open.
-----The car still knows there are windows?
The truck has been fitted with the spring coils and the EAS overridden with an Atlantic British override module. I took out the BECM and unplugged all the sockets, dusted them off, replugged them and that didnt fix the problem. The EAS override module occupies the C114 (green 20 pin) slot and the "cartridge" that went into that slot has be looped through the module. All the components of the C114 cartridge are functioning just fine.
I have attached photos of the switch panel board. Are there burns on it ? I cant tell... I compared it to AVRO's photo:
viewtopic.php?t=8642&highlight= and mine looks similar but not the same (i dont have a crack and i cant tell where AVRO's burns are).
Will changing the switch pack get my windows to open, given its taking current (ie the light lights up)? Is the switch pack the culprit (given the rear windows dont open from their own switches)? If its not the switch pack should I proceed to change the center console wiring harness (or not, given that the console's light is lighting up)?
Thank you in advance,
M
M
