Hello,
I had the same problem and I've sort it out just last week. Nothing would make it eject. Previous owner said just push it for some time :roll: .
What I did, was I took out the cd unit and opened the upper part of the housing.
There you will see a big sprocket about 6cm in diameter (blue if I am not mistaking). This was the hot spot. 8-0= It was jammed and when I helped it to turn, the magazine was ejected, but only worked if I helped it with my finger.
So I took some white grease (similar to that used in moving electrical parts) and greased is a bit under and on the sprocket. I had to eject it and put it back in and played it for for a while, but now it seems to work great.
Hope this helps! :thumb:
Peter
