Car overheating in Neutral
4757 Views 8 Replies 4 Participants Last post by  medcapequip
Guys, took the car to the car wash and while in neutral the Rover started to overheat and the coolant gauge started to climb. I just down the Rover while going through the car wash, when it was finished I started it back up and it started to rise again. I shut down the Rover again and waited several minutes. Turn the Rover back on and drove it slowly back home, weird part was the coolant temperature gauge stayed in the middle.
Now knowing this what can I do to make this not happen again....
1 - 9 of 9 Posts
If your radiator is plugged up you wouldn't be getting enough coolant movement at idle. Water pump failing could also not circulate enough coolant at idle. Higher RPMs allow enough movement to cool the engine.
At idle are you getting heat from your HVAC?
Could his fan clutch be going out too? What was the outside temp when this started happening and do you hear a roar from the engine fan? Before you start throwing money at it, get an obd scanner to verify the engine temps. It shouldn't get above 210F.
3
viewtopic.php?f=3&t=36863&p=287112&hilit=coolant#p287112
I am going to try and add some coolant but after using the search this is the best conversation I could find:
Re: best coolant to use
New postby dutchfrompredator » Fri Feb 05, 2010 4:53 pm
i've been using prestone oat dexcool coolant (orange) in the callaway with good results. can't complain.
Not sure what kind I should try from the auto parts store. There is a Prestone Extended Life, Prestone Dex Cool Extended Life, Peak Long Life and they claim all makes and models, but if that were the case we wouldn't be asking these types of questions....
Any advice?
Outside temp about 52 degrees according to the Rover. I will have to pay attention to the roar part.
I was in neutral for just a few minutes before the needle started to creep to the red. I turned up the climate temperature to HI just in case as I was driving back home.
Even though I do think you have a problem with the engine cooling system that needs to be taken seriously. It would be wise to verify that the temp gauge isn't acting up, mine likes to say I'm running hot even though thats not the case at all. The OBD scanner with live data feeds will verify the engine coolant temp, like I said, it shouldn't get above 210.
I would follow what others have already said here. On top of that, why don't you bleed the cooling system while at it? If you do, be sure to burp the system of air, and wait till the thermostat opens up the system, so you can top up the cooling system. The step by step procedure can be found in RAVE.
I personally use the Prestone Dex-cool 50/50 premix. If you have filled the system before by yourself, and used non-premixed type, hope you didn't put in mountain spring water or some other mineral "drinking water." That stuff can do horrible stuff to your cooling system. You must use distilled water.
Having said all this, taking your car to a car wash can do weird things to your car. I've previously gotten gearbox fault, right after the carwash. I still don't know whether it was the attendant playing w/ the HI/Lo gear, or water spray messing up something. Oh yeah, I've gotten the rear lamp guard broken too, but I suppose that's whole another story.....
I topped off my coolant take with the Prestone extended life all makes all models in the yellow bottle with yellow coolant. The bottle said it is safe for aluminum engines....we'll see.
I drove 50 miles on the highway and the temperature gauge stayed in the middle. I needed to pick something up so I didn't want to put it into neutral and test the patient of the truck.
1 - 9 of 9 Posts
