Just realised that my 'new' p38 doesn't lock! :roll:
If I press the lock button on the remote it chirps twice and I think the indicators flash but nothing locks, If I press the unlock button it sounds like locks unlocking.
If it bears any relation I have a error message saying bonnet open (even when it is shut) will that error cause it not to lock?
RIP Our Friend
Your passenger hood latch needs to be adjusted as the rig thinks the hood is open. Until you adjust or bypass the latch switch you won't be able to lock/arm the truck.
Thanks so it is linked - I managed to get it to work by going round the edge of the bonnet pushing down with my hand after shutting. I've found where the switch is on the RAVE CD so will bypass it tomorrow as a temp measure. I understand it is needed by some processes? Like when it tells you to check oil it won't clear until the bonnet is opened - is that correct?
