Hello everyone,
My 2007 RRS SC is leaning right, and we cannot pinpoint the problem. I went to 2 different LR shops, and I am 5k into this problem with no solution.
Here is the situation:
What we have done:
I don't ****ing know what to do at this point. 2nd LR shop is now recommending replacing front and rear valve blocks too. I feel like everyone is just ripping me off without doing a proper diagnosis.
TL;DR:
- Car is tilted to the right few inches. Various attempts to do calibration didn't fix the problem.
- Car lowers overnight, but if I turn off EAS with my GAP tool (or by pulling the fuse), it does not lower. - I feel like this means I don't have any leak.
- LR shop did a soap test and didn't find any leak
What we have done:
- 1st LR shop thought that the front-right strut was leaking. We replaced it, and the issue didn't go away. TBH: I don't think my strut was leaking because the car sits stable if I disable EAS with my gap iid tool.
- They tried to calibrate the suspension, and they told me that they are getting bad data from the rear-right sensor. We replaced the sensor.
- They tried to calibrate the suspension again, but now they told me that the air compressor is weak and cannot do the calibration. At this point, I lost my trust in these guys and went to another LR shop.
- 2nd LR shop told me the same thing about the air compressor and they recommended replacing it. We ended up replacing a perfectly working -but weak- air compressor with a brand new AMK. They did the calibration again but that didn't solve the problem either.
- At this point, I decided to replace the front-right height sensor by myself to eliminate another potential problem. It was easy to access so I replaced it myself and tried to re-calibrate it with my GAP IID but the car is still leaning right.
TL;DR:
- New front-right strut
- New front-right and rear-right height sensor
- New air compressor
- 6 months old front-valve block
- Various attempt to do calibration but car is still leaning right
