So my car charger in the fron and in the back seat of my 2008 range rover is not charging. Probably a fuse. Does this fuse power anything else? Where is the fuse box in this vehicle? what kind of fuse is it?
thank you
I had to read this twice.
So I'm imaging the lack of responses is due to the kind of vague weirdness of question.
You're owners manual will point you to the fuses & looking at the fuse map you'll see which controls what & its rating. Not sure if fuse box is in same area as the earlier ones but look in glove box & under drivers well.
It definitely sounds like a fuse. Is anything else off???
I think the "cigarette lighter" in the front (underneath the analog clock) is on a separate fuse. I believe the other three outlets share one fuse, but I'm just going by memory.
Sorry for the confusion. I has read some posts where it stated that the fuse for the car chargers isalso for the navigation and other things. In my case the two car chargers are not working. I'll look at my manual. Thank you
Never heard of power points (cigar lighter sockets) refered to as car chargers! New one for me... Now I understand what the post was about.
