I can't open the hood on my Rover. I did a little research out here and found a couple of suggestions but none worked.
Here is the issue: I pull the inside release lever all the way. However I didn't hear the normal hood popping sound but instead just a light click. The hood also doesn't pop up enough on its own to allow you to reach the release lever. Thus I pull up on it a bit and pulled the release lever. However, this doesn't allow me to raise the hood as the passenger side is still stuck down.
Here is what I have done so far:
Closed it and tried it again (and again and again).
Pushed down on the hood while someone pulled the lever.
Pulled up on the hood while someone pulled the lever.
Nothing seems to be working. My suspicion based on some reading is that this is possibly due to a release cable being broken but I am not sure. Any ideas?
