My Range Rover (2000) model drained the battery and when I returned from recharge I the engine was disabled. The alarm cant go off, and I just cant put the code at the door as per user manual guide. Help please.
I had a similar problem with my truck when I bought it, the previuos owner took everything including owners manual and security cards out of the truck so I had to re-key the truck and get the code from landrover to set the door locks and alarm. Fun!
I have tried all the tricks you suggested but it didnt work. It simply gives a 'blip' each time you turn a switch. At the end the alarm goes off and the engine is still disabled. Any new ideas ?
Get in touch with Rick (above) adn get your BeCM sent off. Once your BeCM locks you out this is the only option other than a new unit and a VERY expensive trip to the dealer. Rick can get you fixed right up for a fraction of the dealer cost.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
