Can 'powered' running boards be removed and not leave holes or finish issues???
If an 08' came with power running boards can they be removed without damaging the finish or leaving holes or witness marks that they were there before? Any cockpit or cabin switch holes? Thanx!
Re: Can 'powered' running boards be removed and not leave holes or finish issues???
No damage or marks will be left after they are removed and the mounting holes were already there before the steps were fitted.You will need two rubber plugs to block the holes that the wireing goes through to the inside of the car.The switch which is in the roof consul will require a blanking cover (from Landrover) to fill the hole when the switch is removed.
