Ok I found some of the info I was looking for.... and more.
This is the link with more info & pic of before and after of the oil pump.
http://www.gomog.com/allmorgan/oilpumpbase.html
I also recalled people with way more knowledge than me saying it is a bad idea because the original face is anodized and the resurfaced face is now just soft aluminum.
"The surface of your oil pump front cover does indeed look rather scored. When new, the entire cover is anodised so as to maximise the useable life. Once the anodising has been worn through, as it the case of the visible scoring present on your cover, further use has ended.
As you expected, it is a pointless exercise in sanding the mating face of the cover to as to eliminate the score marks. The entire face is then free of the hard anodising, and if used in this state, soft aluminium debris will quickly fill the engine as the spinning oil pump gears eat into the cover.
The only viable solution is to purchase another cover." Not so viable anymore. Found a few new ones for sale for around 300 pounds! Full thread is found
here.
Which made me wonder & search more. Came across a
thrust plate kit by Melling for the Buick 215. I wonder if this would actually work?!?
