1 - 1 of 1 Posts
i recall reading that some countries have separate cornering lights built into there l322 headlights. i think after looking at my US spec headlights i see where the bulb would go. wondering if it is reasonable to convert these housings to have cornering lights. first task is to get the bulb installed, then figure out to use factory wiring or build a system, i currently have the correct relays to build the wiring if needed
thanks
1 - 1 of 1 Posts
