2006-2009 Range Rover P38A
Should change alternator, and when i remowed the generator there was no cable to D+.(Field)
I search and I couldent find any suitable kabel anywhere..
Where does it came from,something should go to chargingbulb..
Anyone who know.
Just because a post is there does not mean it is used. The battery charging light is fed from the BeCM, not direct from the alternator. Details, wiring schematics and pinouts can be found in the RAVE manual
There should be only 2 wires to the alternator.
The main +ve charging feed to the battery, and a smaller wire (Brown/Yellow) that connects from the alternator to the BECM to tell it that it's charging.
If you are missing the smaller one, then it is probably buried in the loom or under something around the engine... but it shouldn't be far away from the alternator and main battery wire.
