1 - 1 of 1 Posts
2006 RR HSE
I'm getting a code C1A13. In the past year I have replaced my compressor and 3 ride height sensors. Every since I have been getting the code. I also can't raise my Rover to the top height. When it's at it's normal ride height and I push it up I get an error. It also won't lower to the lowest level. There are no leaks and the compressor works fine. I've tried taking off the brass piece that I believe is the silencer but that didn't work. I'm not sure where else it could be clogged to cause it not to release pressure. Any ideas?
Rob
1 - 1 of 1 Posts
