On the female end of the EAS ECU what 2 pins would I use if I wanted to run 2 long wires from the compressor to the female end of the EAS ECu connector?
So basically I am trying to find out what 2 pins will provide a constant 12 volts so I can connect them directly to the positive and negative of the compressor to get it to run.
Thank you for your help!
