Hello folks .. looking for some help. This will be my first RRS and 4th Rover. I have found a good enough deal. I had the car overnight to check things out. Service book is stamped. The car has 28k on the odo. As far as I can tell it needs new wiper blades , tires are a bit gone but will be replaced with a set of 20" wheel/tires. What is your suggestions for checking expected brake wear? The only issue I see is that is has the noisy steering column that I have read about here. I read through a bunch of threads here and am making sure I have not missed anything. I will probably ask for the new bluetooth update as well. Any other demands I should throw in to the deal? Anything else to look for? How long should the suspension make noise after adjusting in to different modes (off road , standard , and low)? It seems like it can go on for a while. I will request a complete service history. Warranty expires in 9/10. I will probably sell it by then. Would you pay $2400 for an additional 5 year 50K ($100 Deductible) for the sole purpose of resale value? Thanks in advance for any input!
Casey
Casey
