OK. I now am on my 4th fusebox in 12 years of ownership of my p38. I placed all three burned fuseboxes side by side, and all three are burned at the RL7 relay (LH Blower Motor). Even the carbonized burn marks are identical in shapes. My local Land Rover Stealer (who are actually pretty good guys) just today told me that they still just change out fuseboxes and that there is no technical service bulletin for this problem. Well, simply refitting fuseboxes is not an acceptable engineering practice in my book when we KNOW that a burn will result. This isn't a hypothesis anymore, it's almost a scientific law by now. Isn't stupidity defined as doing the same thing over and over and expecting a different result? Also, this BS about pollen filters clogging and causing the LH Blower Motor to work too hard is pure nonsense. If clogged pollen filters were causing this problem, then we would be seeing burns on the fuseboard at RL6 (RH Blower Motor) as well. But there are not any instances of of burned fuseboxes at RL6 that I know about. They are all at RL7. I have had enough of this BS!! I am not finding any solution on the internet in general or this website. Has somebody come up with a solution?
I am interested in soliciting ideas for a solution that actually works. So far I have come up the following:
1. create a 4-wire pigtail with 10 ga wire and remotely locate the RL7 relay OUTSIDE the fusebox.
2. take a Bosch-style ECU cooling fan and cool the fusebox.
3. run a really heavy (8ga) primary wire from the fusebox to the LH blower motor to reduce resistance.
Does anybody have a better idea? or any idea that that actually can make the RL7 portion of a fusebox last longer than 2 to 3 years?
Tom
1996 4.6
228k miles
LR322 modified expedition rack
Tom
1996 4.6
228k miles
