1 - 17 of 17 Posts
Does anyone have a list of the bulb part numbers somewhere?
i think my rover has the wrong bulbs in some sockets which causes them to not work sometimes. and then i get nice messages in the display. really annoying.
i need to know what the turn signal bulbs are numbered. i have clear indicator lenses and clear bulbs in there :?: shouldn't they be amber?
also what are the brake light bulb numbers and the tail light number?
i searched but i did not find anything in the rave manual or the forum. maybe i'm looking in the wrong spots.
thanks
i don't have an owners manual and the one on RAVE doesn't list them as far as i can tell. it only lists the watts each bulb uses.
i swear the rave manual i have sucks.
wreckrunner said:
I will look up all of the Sylvania bulb part numbers for you tomorrow on the Mitchell system at my shop!
That would be great to make an article for the main site about that bulb issue.
The info in RAVE, Section 04 General Specification Data -> Information -> Replacement Bulbs (Page 18) should be sufficient. The type of bulbs are quite standard and common. Unfortunately, not all bulb bases are quoted in that section.
My desktop PC has died and I don't have MicroCat on this computer. I suppose I could drag out the paper copy I have of the P38A Parts Catalogue.
I did a search on the Advance Auto parts site when I had to find out bulb types.
I find it interesting that some folks have no
Owners Manuel, yet I have 3 :think:
Ok, these part numbers were gleaned from my Carquest Auto Parts weblink..
Low beam headlight....9003
High beam headlight...9005
Rear brake and turn....7506
Front turn signal........2825
Front fog lamp..........H1B1
Licence plate lamp.....2825
High level brake........2825
Side repeater lamp.....2825
And that is all they list, they do use some quirky part numbers but the numbers listed are used by the common manufacturers, Phillips, Eiko, Warner, etc. Hope this helps! :thumb:
Discussion Starter #13
can someone post the bulb numbers. everywhere i check has different numbers. i'm really tired of the bulb warnings.
thanks
SUPER MODERATOR
ANything we post would be different as well. Just look up the bulbs on the Sylvania site or go match up the wattage and bases at OReilly's/NAPA/Schucks/Pep Boys or whatever is close to you. Our bulbs are as basic and generic as they get.
Discussion Starter #15
this is from one website. i'm going to organize this a little better. give a little bit to fix it.
not sure if the numbers are 100% correct
Headlights:
9003, Low beam
9005, High beam
Back Up Light
12498
Brake Light Bulb
12498
Application: automotive - signal. Cross reference: ECE Type: P21/W, GE (P25-1), Osram Sylvania (7506), Philips (12498).
Courtesy Light Bulb
12516
Dome Light
12854
Fog/Driving
H1
Glove Box Light
12844
High Mount Brake Light
12498
Instrument Panel Light
12516
License Light
12961
Map Light
12929
Parking Light
12499
Side Marker Light
12961
Tail Light
12821
Trunk/Cargo Area
12814
Turn Signal Light
12498, Rr.,
12499, Frt.
12961, Side Marker
1 - 17 of 17 Posts
