That's a good point. I've always had terrible trouble fully bleeding the system. The method I use that seems to work is to top up the expansion bottle, then run the engine up to temperature with the lid of the expansion bottle still off, then let it cool full (overnight) still with the lid of the bottle off. In the morning top up the coolant as necessary, refit the lid and off you go. It's a bit of a pain, and there may be other methods that work, but that's the one that works for me.classicjack said:While trouble shooting dont forget to bleed cooling system, fill from metal heater line tower with rad plug removed until water flows out of rad. This removes any air in lines, which sometimes cause overheating or bubbling.
Hard to tell if there's steam coming out of the exhaust... its white exhaust fumes and always has be (it runs on LPG)Danny said:It probably means bad news. Likely you've got compression gasses leaking into the cooling system which means head gasket or cracked head or similar.
Have you got steam out of the exhaust pipe as well?
The radiator hoses arn't hard but if you squeeze them the water level rises in the radiator from pressurenateb006 said:Are the radiator hoses hard or do they show any signs of pressure after the engine is warmed up and has been ran for twenty minutes or so?
