Hi guys, I appear to have Brembo GT Calipers fitted to my 2005, face-lifted 3.0 td6. They are the 8 pot Calipers fitted by overfinch.
Anyway, I need new discs which is proving difficult As they appear to be 380mm floating discs and nobody it seems is able to help with getting the part number.
Has anyone got similar setup and no the part number of the discs and do they need to be the floating discs which are insanely expensive it seems.
Thanks guys.
286635
286636
286637
I wouldn't think you could use a fixed disc with this Brembo kit. At the very least, the diameter would be off since these are larger I assume. But you could sell the kit for probably enough to go back to stock and future cheap replacement discs.
I have a 2007 with the same brakes. The friction ring part numbers are 906536 & 906537. You'll also need new hardware for each friction ring 915506 x 2.
