I have a 98 p38 I just got. I shudder at brake issues mainly due to some of the costs I see with everything.
Here is the problem I'm having. When the rover is started first thing in the morning I get hardly any brakes first starting out. The pedal will go to the floor if I press hard enough and I have hardly any brakes. It doesn't matter if I warm it up 10 minutes or just go and it's only first thing after it has sat overnight.
After the first couple times I pump the brakes, they are at full pressure and work great the rest of the time all day long.
I can hear the "pump" come on pretty after 1 or 2 presses of the brake pedal. It comes on for about 3 seconds and then turns off. I press the brakes again 1 or 2 times, it comes on for 3 seconds, then turns off. I have full fluids and it doesn't appear to be leaking any brake fluid. No warning lights on the dash.
So, any ideas on this? I was reading about the accumlator....and that doesn't seem to be the reason this would happen...or is it?
Thanks for any help.
