Hey guys,
Is it necessary to have a Diagnostic Tool to bleed the Brake system instead of pressing and pumping the the system with the brake pedal?
Sent from my ONEPLUS A6003 using Tapatalk
Doesn't matter - standard bleeding processes apply - nothing special about the RRS - start with the wheel the longest distance from the master cylinder and end with the shortest - ABs system is not a complication as the fluid goes through it as the wheel cylinders are bled.
Dont make things harder than they need to be.
I spoke to a LR tech earlier today. In order for us to remove all brake fluid from the abs system for any LR 10' and up, the system has to be bleed using a Hawkeye controller or a iLand app to fully removed all brake fluid. For 09' and older this is not necessary.
