can anybody help me i have a 1998 2.5 dse when ever the engine runs the brake pedal goes down slowly but if the engine is not running the pedal is solid there is no loss off fluid from anywhere could it be the master cylinder any help will be thankfull
You have a ABS pump that builds up pressure of 80bar, when the vehicle stands for awhile this pressure bleeds off and is normal.
Without starting the vehicle the pedal will be hard, when you turn on ignition you will hear a whinning noise, this is the ABS pump building up pressure, if you now apply foot pressure the effort to apply the brakes is a lot easier than before.
In a nut shell seems your brakes are doing just fine
thanks for your reply the car has been ok till today when i drove it today the brakes feel like they are going to go altogether hope this helps
