My P38 Range june 1997. I have a few problems. Three months ago : Christmas tree, suspension problem.
I install news air springs and replacement of all the seals in the air box. All is OK.
But 3 days later new Christmas tree and issue with the brakes.
Immediately I see the ABS pump is not running. I control fuses and relays. If I put a shunt Instead of the pump relay, the pump is running good. I check the ABS pressure switch connector and I note the feeding of the electricity is not 12 volts but 7 volts.
Why this fault. Where does this feeding come from ? What do I check ? Where do I look for ?
Many thanks for your answers and excuse my bad English.
Pugna in France
Cher Pugna,
Avez vous le Rave (Manuel d'atelier)? La réponse doit être dedans: sur 1300 pages pdf, il doit bien y avoir le shéma de la partie ABS.
