Got the warning today but all of the pads look good from the outside. Anyway to tell if it’s front or back without taking the wheels off?
Sorry @chris92229,but you can't tell if the pads are worn from looking at the outside of em ....if the warning has come on then before you damage the rotor you should change them ....that's my thoughts.Got the warning today but all of the pads look good from the outside. Anyway to tell if it’s front or back without taking the wheels off?
Well clearly, if I can’t see from the outside and the sensor is on the inside, then it’s one of the inner pads. My question was more along the lines of, is there a sensor on the front and rear or is there somewhere that tells u if it’s front or back other then using a GAP tool? I don’t care about the rotor because I’ll be changing them as well. Thank you though.
