Are all 15 warning lights supposed to illuminate on the instrument binnacle when the key is turned to position I? All of my lights turn on except for one, the brake pad wear warning light (First Column Second from Top). I know the light works because I can jump the two pins on the harness at the brakes to get the light to come on. However, it does not illuminate during the initial startup.
If it is supposed to light up does anyone have any ideas as to what could be the problem? Possibly the bulb check unit?
