1 - 13 of 13 Posts
I have been looking all over for the clip that holds the pad sensor in place but having no luck. I have a 2010 sport hse. One popped out and I can find it. Closest dealer is over an hour away. Was hoping to just order it online. Does anyone know what it is called as any combination of words I have tried has failed, or have a part number?
Thanks!
· RIP Our Friend
doesn't fit into the caliper. There are only two on any LR product. One in one of the front inboard pads and on in one of rear inboard pads. It is a simple band of metal that when your disc wears through it the pad wear indicator system alerts you to pad wear. Then is up to you to take a flash light and look through the spaces in your rims... if they are big enough, and figure out which end is wearing. Most of the time it is front pads. Front brakes wear two to one for rear brakes.
That little clip is integral with the sensor - you need to buy a new sensor - not expensive. As mentioned clips into the metal backing plate of the brake pad.
Ok some pics as I have new pads and a sensor in my parts bin.
This first pic shows the pad and the end of the sensor - you can see the metal clip in the slot at the end of the sensor - you can also see the slot in the pad that the sensor pushes into
IMG_20190304_121700_1
Here is a pic with the sensor pushed into the pad - the metal clip is a spring and holds the sensor in the pad
IMG_20190304_121732
I hope this helps.
2013-2015 Range Rover Sport
But before you burn money, check the caliper -- the clip might still be in there and didn't pull out when you removed the sensor. Had this happen on a LR3 a few years ago: tried to insert the new sensor (with the new clip) and it wouldn't fit; so down on my knees, pull out the flashlight and mirror and and voila, the old clip was still in place and blocking the installation of the new one.
1 - 13 of 13 Posts
