They are on some good crack and not sharing :naughty:
I have an 08 RRSSC I have 30K on my front pads, and they are a little less than 50% gone ( mine look thicker than the pic posted above), when I looked at them at the dealer this past friday, even the tech said they didn't need new pads, and couldn't believe I haven't changed them yet. Keep in mind that 98% of my driving is all highway 70+ mph.
You can get a complete kit and replace the front and rear pads, rotors, and sensors from Atlantic British for $849.95. I ordered this Kit last week, to be prepared for when mine needs it.
http://www.roverparts.com/Parts/8857EBC.cfm
EBC Performance Brake Kits for Your Rover from Atlantic British!
Improve your Rover's performance on and off-road!
EBC Greenstuff Triple-Award-Winning Pads provide higher thermal conductivity that virtually eliminates brake judder, with better cold braking for shorter stops and less fade and better wear for longer life. These 6000 series pads are specifically made for 4x4 use and offer better resistance to off-road conditions of dust, sand, etc. They have an extremely low rotor wear factor and medium-to-good lifetime.
EBC Sport Rotors are designed for heavier trucks like your Rover and are especially good on lifted trucks or in towing applications. These rotors are dimpled and offer a wider slot that provides better cooling, while expelling dust and dirt better than fine slotted rotors. Since they are dimpled (not cross-drilled), mud and grime does not lodge in drill holes and the dimples actually shed dirt and mud well.
Our Kits Include: (4) EBC Sport Rotors, (2) Sets of Greenstuff Pads and Brake Wear Sensors!
Performance Advantage!
EBC Greenstuff Pads:
• 6000 series pads are specifically made for 4x4 use.
• Excellent in cold and hot conditions effective to above 1,200° F!
• Low dust formula.
EBC Sport Rotors (Dimpled & Slotted):
• Wide aperture grooves.
• Special disc alloys UNIQUE to EBC.
• Dimple hole construction.
• Balanced geometry.
Click Here for Frequently Asked Questions on EBC Brakes.
Kit includes the following components:
# Product ID Description Qty. Required Qty. In Stock Cost
1 8854EBC
Brake Rotors Front EBC Pair 1 On Order $459.95
2 8856EBC
Brake Rotors - Rear - EBC Performance - Pair 1 Yes! $292.95
3 SEM500026
Brake Pad Sensor Front - Supercharged Sport 1 Yes! $37.95
4 SFP500070EBC
Brake Pads Front 1 Yes! $91.95
5 SFP500140EBC
Brake Pads - Rear - EBC Performance 1 Yes! $59.95
6 SOE000025
Brake Pad Wear Sensor - Rear 1 Yes! $17.95
Total Value: $960.70
Your Cost: $849.95
You Save: $110.75
