1 - 1 of 1 Posts
FOUNDING MEMBER
I replaced the front pads and rotors on my 2004 RR yesterday and now I have a mushy pedal. My next step is to bleed the system, I am planning on using the Motive pressure bleeder. I read the RAVE manual on bleeding brakes, but I did not see anything about the ABS part of the system. Will the ABS system get flushed out at the same time or is there a separate procedure for ABS.
Also, has anyone used the full synthetic DOT 5 fluid? Not sure if it is compatible with BMW/LandRover system. How about the Super Blue Fluid?
Marc
1 - 1 of 1 Posts
