Does anyone know the size of the bolt that is used to remove the brake caliper off of a 1993 RRC?
Am I correct in assuming its the "star" bolts I need to loosen to remove the caliper? Also, what is the best way to remove this bolt? By air or by hand?
My caliper seals are bad, I have brake fluid leaking all over my rotor (passenger side front), and it was puling to the side before the fluid starting leaking out soo bad over the rotor.
Any help would be great!
Thanks in advance!
Andrew.
Thanks in advance!
Andrew.
