Hi All,
I'm new to these forums and to Land Rovers in general, unless you count lusting after one my entire life. Today I brought home my new pride and joy, a 2005 Range Rover HSE with 195k miles.
So why buy a 2005 with 195k for my first RR? Well, I was browsing for a beater 4x4 that I could use to have some fun in (thinking a Montero, maybe a Trooper), when I came across this RR listed for $1k. The listing said it had a bad air suspension and needed a new catalytic converter but that the engine and transmission were strong. My palms grew sweaty, I licked my lips. What if I could make this work? I pulled the Carfax and this sealed the deal:
The best part is that all those service records were at a Land Rover dealership. The last recorded service was 5k miles ago, but I figured, "how much can go wrong in 5k miles?" (spoiler: a lot). So I contacted the seller, got him to come down to $800, then had it towed home due to the bad suspension.
So, as I'm brand new to Range Rovers, I'm going to use this thread to document the stuff that's wrong and if I'm able to figure out how to fix it, how I did it (or at least link to the resource that provided the answer). I would love to utilize the collective wisdom of this forum as well, so if you have suggestions, please let me know, as I'm a complete noob when it comes to this car.
So, my current list of what I've identified as mechanically broken (I'm not worried about cosmetics right now):
So, I'm going to start digging into these to try and find answers on this forum and others. As I previously said, if you see a problem and immediatelyknow the solution, any feedback would be greatly appreciated.
Thanks all!
- Hood release latch by driver's foot is broken. The cable is also stretched and needs to be replaced.
- Hood struts are bad.
- The key requires quite a lot of steering wheel jiggling to turn in the ignition. So far it has always turned, but it takes a solid ~30 seconds of steering wheel rotation back and forth to turn
- All four corners of the air suspension are bottomed out. Bad compressor?
- Error message "HDC inactive", so hill descent has some issue
- The seller said it needs a new catalytic converter, but there's no check engine light, so...maybe?
- The seller said it needs a new blower motor. Haven't tested the air yet.
- The Dynamic Stability Control dash light is on
Thanks all!
