1 - 10 of 10 Posts
When I bought my Range Rover battery was dead and their was a leak in brake lines no fluid! the brakes are fixed! but air suspension inactive an I am on bump stops checked all fuses relays etc their good checked pump took it out looks new it works sounds like it’s pretty new! I bought a few cheap scan tools no luck! I have air suspension inactive an no lights on rocker switch on bump stops! Oh it was towed in had fuse 37 installed for towing I removed it an their is no switch to turn off your air ride like fords so?? what diagnostic tool should I buy? Any help u can give me it would be very appreciated!!! I was gonna do the conversion to springs tell I read a bunch of forums so I wanna keep the air suspension please help me do so...,
You absolutely need to buy and own iLAND from roverparts.com
It’s a Bluetooth adapter that links to your iPhone or android and lets you investigate any air electronic suspension faults (eas) and reset them.
Any progress?
Any progress?
I didn’t wanna spend 400 was thinking about rsw for $227 I need a diagnostic tool so I can get suspension to work
Got it.
Recalibrate your steering wheel angle sensor. Turn wheel lock to lock
Any other warning lights on the intrument panel on? ABS, DSC, HDC?
No warning lights at all, except air suspension inactive and I have to change a turn signal bulb passenger side fender it said after air suspension inactive was not worried about that at moment and the rocker switch for the suspension next to the clock to the left no lights either at all!!
1 - 10 of 10 Posts
