First, want your junkyard here!
This was just covered.......Should be no problem. The newer seats will have side airbags, so you will have nowhere to plug them in.
The plugs are self shorting. If you wish to cut them off, solder the ends together, and tape up (Keep the airbags from triggering accidentally)
Otherwise, the other plugs should be the same.
You could confirm by looking in Rave and comparing plugs and pin outs.
