Does anyone know if the Bosch ECM from a 99' Disco II will work in a 99' P38 with same 4.0 Bosch engine, asssuming it is programmed with a T4 or Rovacom ? They look identicle but the part numbers are different. Thanks.
Different signals etc, for example transmission ABS and even AC request
You'll find there is a way to get it working but not woth all the hassles
Why not source a P38 ECM uses the same for 4.0 and 4.6 on the GEMs and the Bosch, can be reconfigured using software and needs to be as ECM is linked security wise via the BeCM
