Does anyone have any idea where the bonnet sensor is actually located and how to adjust it ? Mine constantly beeps when ever I go over a bump.
I would remove the latch and make sure the micro switch is firmly seated first. It is only held in my plastic retaining tabs which can flex when warmed by the engine heat. Be careful when installing and adjusting as the latch is only a pair of screws into plastic unlike the other side which is bolts into metal. If all else fails disconnect and jumper the two wires.
