1 - 13 of 13 Posts
Decided to remove my bonnet lining and as I was pulling it off broke the clip that holds the windscreen washer in place the clip has a pipe running through it and looks like this
[attachment=0:cqwsk3v9]090520100681.jpg[/attachment:cqwsk3v9]
Any one know what the part number is for it as it is not listed in microcat?
RIP Our Friend
Re: bonnet liling clip
Call Brian at Atlantic British and he can send you out a couple. They are a couple dollars each.
offroadbaz i dont think its that one the three that clip the pipe into position are fine, the one im looking for is the only one like it and makes a connection between the two pipes it actually is part of the piping system, you may be right though as I can find a picture attched to that part number
Jeremy,
I think the part you need is #20 in the callout, which is ALR4425.
It's strange that there's no info about #24 in Microcat for any P38 model.
Hope it helps,
N.
G
JeremyD, With the help of diagram you are teaching us. You have done a great job carry on with this. But which part you needed in this diagram part number 19 or 20 because NachoMan77 says part number 20 so I asked.
1 - 13 of 13 Posts
