iPhone 4s used to pair fine, 2005 Vogue 4.4, venture cam still works fine, iPhone now does not connect after latest Apple update, is there a way around this?
You might try searching under apple update/iPhone update. We see these kind of posts after each update because apparently settings are returned to default on phones.
on the Iphone go to settings, Bluetooth, under devices you will see land rover, click on the arrow to the right and forget this device, now turn the Bluetooth off and back on and re add the Bluetooth audio device, the code should be 2121.
