Ive replaced the fuse box with new, including relays and still can't get the fans to work.
Which connector and pins on the becm go between the becm and climate control unit. Also, which is the wite that goes directly between the becm and the relay?
There are piles of wires that go from HvAC to the BeCM. Go to section K4 in the RAVE ETM and everywhere you see the BeCM and HvAC record the connector number and wire colour. You are on your own for that homework.
The wire that goes direct is connector 112 at the Becm pin 8. White and light green. This can be found on diagram 5 in the above reference.
