2002-2005 Range Rover P38A
2002 rr 4.6 HSE US model - Pass side blower motor ran constant at full speed, checked relays and notice number 7 burned and slight melt and cracks under it on fuse box. replaced the relay but noting changed so I unluged the red wire from the pass side blower. drivers side blow ran the way it should so i left things that way. after reading other posts I was thinking the pass side blower may have shorted transistor(s). now the drivers side blower is not working at all and the new relay #7 is burned again. Question is should I focus on the fuse box or the transistors pass side transistor first. I did not yet check the fuses under the pass seat since the drivers side blower stopped working but will. Any direction for me?
Start with pollen filters, then fuse box, then call me for blower motors.... :lol: :lol:
IF YOUR FUSE BOX IS CRACKED AND BURNED WHERE RELAYS AND FUSES GO U SHOULD REPLACE FUSE BOX AND IF BLOWER MOTORS STILL DONT CHANGE SPEEDS THEN REPLACE THEM ALSO THERE IS A CONNECTOR FOR THE MOTORS BEHIND PANEL RIGHT PASS SIDE MAKE SURE ITS NOT BURNED AND MELTING
