There should also be drain holes or passages of some sort in the cabin air intake duct on the "dirty" side of the pollen filters. This is the duct leading from the outside cabin air intake between the hood and windshield that runs to the pollen filter on each side. My Rhino was clogged with wet leaves when I bought it because the thin screen covering on the cabin air intake had deteriorated. Water can certainly get in there and it needs to be able to drain out. I replaced all of the filters, shop-vac'd, cleaned everything I could reach and have not had a problem since. New pollen filter cover seals would not help if this is the problem.
