Hey y'all, my '00 4.0 has been exhibiting some very weird emissions/code behavior:
P0135/0155
Went through a handful of O2 sensors before I got a pair that worked (DIY writeup coming soon). The new sensors switched like a charm in the live graph and both fuel systems gloriously went closed loop for the first time in months. :thumb:
However I cannot get this persistent 02 heater circuit bank 1/2 sensor 1 code to go away. It's two white wires and a resistive element - not sure what could possibly be wrong. The ETM implies that they're powered through the Ignition coil relay - but doesn't specify where that is to be found (my brain turns to mush when reading the ETM so that doesn't help...).
IF it's a bad relay that totally makes sense that it would theoretically also cause:
P1300/0303/0306/0307/0308
A whole lotta misfires! Plus random multi misfire. Cyls' 3,6,7 & 8 so doesn't sound too likely it's a single coil gone bad. Dual coil failure? 4x wire failure???
The CEL flashes occasionally, usually under load at freeway speeds - hitting a big hill for instance. Never does it in city driving. Oddly there's no noticeable difference in engine performance weather it's flashing (misfiring?) or not. Runs smooth, seems to pull fine if I mash the throttle, etc. Never once felt the classic misfire roughness or even the slightest shimmy.
And that's the mystery.
Help?
P0135/0155
Help?
