Hey all out there in love hate rover land ... Im up in Canada with my 2006 S/C Range HSE imported from the States and supposedly has the adaptive headlights that move. However if parked in front of a garage door or wall they do not raise when the vehicle is started. Anyone know what might be a common cause. We're they standard or optional. I was under the assumption standard. So if they are standard what may be a few common causes as to why they arent moving...?? Any ideas from the wealth of knowledge on the forum?
cheers
From inside the engine compartment, the regular xenon lights have a black plastic domed cover which removes using a plastic clip to expose the wiring which 1/4 turns to remove the lamp connection. The adaptive is a bit more complicated.
Post a photo and we can ID it for you.
