Happy Christmas all..
I thought id spend some free time fixing the passenger blend motor problem on my 51 plate.
The motor wasnt turning at all so picked up a second hand one from fleabay.
On inspection the replacement motor had teeth broken so ive swapped gears from the original but im not sure on the setup.
The grear on the top of the Pot and the big gear that drives the heat control flap have small arrows on so presume there is some set up timing.
Ive guessed, but its not playing ball.
DO i need to reset anything ?
When I turn ignition on the motor looks for a home point. If I move the pot to about half way it will stop. Turning the pot left then right will make the motor change direction so I think the motor is ok. If the pot turns all the way around the motor stops and wont then turn until the ignition is turned off and on.
Cheers for any advice :mrgreen:
