I've put a new thermostat in to cure the engine not getting up to temperature.
I've bled the system as best I can and according to RAVE, but I've obviously got air in the lower half of the thermostat. As such, it's not getting hot enough to open.
The gauge is getting up to the middle quite quickly and I've let it get up to 95c (203F) and decided that's hot enough so switched the engine off to let it cool a bit.
I've tested the thermostat opens and closes using hot water from thekitchen, so I know it does work and opens at the right temperate.
Any tricks to do this? I even tried heating up some coolant to boiling and quickly pouring down the small pipe that goes to the top of the thermostat housing with no success.
