You'd see some sparkles in the oil, too, from the tensioner beating its way thru the back of the guide. That's not magnetic of course so can't use magnet to collect the bits. more relevant, the bits are too big to show up on blackstone's equipment.
btw I found the most definitive proof was, sometime when it starts and the slapping is particularly loud, stop right away (engine off) and pull the oil fill cap, then use a right-angle pick and see if the timing chain is loose, or taught like a guitar string.
I did the same blackstone report and mine was clean too... in the middle of replacing the tensioners/rails now. wish me luck.
