Its been a while and its good to be back and then again maybe not so good.
I have a BIG Electrical problem and hope you members have some clues as to what is going on here. With the key OUT of the ignition I am getting a orange fuel light, red fuel light, SRS light, AIR BAG FAULT, mileage is on. Turned switch on and no instrument lights come on. But then I get the ELECTRICAL FAULT warning, then the FUEL GAGE FAULT, AIR BAG FAULT warning. Started motor and the fuel light and temp light still on and the dials don't move. Turn signals work but no arrows on the dash, ABS light comes on and off. Shut off motor, pull key and the fuel and temp lights stay on, SRS, ABS, mileage stay on the the ELECTRICAL FAULT, AIR BAG FAULT stay on, all with the key out of the ignition. Then after short time the dash goes dark and the lights back up with the Faults. It starts and runs fine and the air ride system seems to be unaffected by this. I checked the voltage across from -to+ and it is at 12.75 volts. ANY HELP from you members would sure be a big help to me as I just don't have a clue as to what is causing this. Best Regards Skip R :?:
