1 - 18 of 18 Posts
Looking for some help. I need to replace all 4 tires on my 2016 RRS Td6. I am hearing great things about this tire and my local Discount Tire store seems to have them in stock.
Most of my drive is on pavement, usually bumper to bumper traffic on the highways. Only once or twice a year will I take my RRS off-road. My wife's car is better suited for vacations due to cargo room and space between the 2nd/3rd rows seats are much better than my RRS.
My questions/concerns are:
1) Is this tire quite on pavement/highways at multiple speed levels... If there is no traffic, I will drive 85 or higher mph. Reading some of the threads, it seems like this tire is heavier than the stock and my fuel averages will go down a bit. Not overly concerned with losing one or two mpg.
2) I do drive cautiously, but a bit aggressive. After all, I have to justify the Td6 somehow. Which leads me to my third question...
3) How will this tire respond in the stop and go traffic.... There are times, I will do 60 or 70 mph, and have to quickly slow down due to traffic congestion. Heavier tire or thread on KO2 may not help with fast braking or handling?
Thank you all for your help. I need to replace the tires today as I have a flat and the tires needs to be replaced anyways...
Got the KO2 installed. I was in a rush to get new tires and did not have enough time to research.
The ride seems to be a bit stiffer than the stock tires. Perhaps, after a few miles, it will get better. Here are some pictures.
Land vehicle Alloy wheel Vehicle Tire Car
Land vehicle Alloy wheel Vehicle Car Wheel
Land vehicle Alloy wheel Vehicle Wheel Tire
2016 Range Rover Sport
I have had T/A KO2s on for the last year or so. They are quiet. I have not noticed a change in my gasoline use. They are fine for stopping. However, you will have to reduce cornering speeds. They are great in deep snow, off road, and tarmac. They are competent on ice but not the best.
I do not regret getting them.
Land vehicle Vehicle Car Automotive tire Tire
I think after couple of hundred miles, the tire and I will get used to each other. The Discount Tire store folks put one tire on first and asked me to check it out. They were hesitant to install them as they felt there was not enough clearance. I assured them that after putting all four, it will be OK.
These look great and work well for occasional off-roading.
I had 275/55R20 KO2 D rated on my 2016 RRS HSE for about a year.
They are surprisingly quiet for an A/T tire and how meaty they are. I experienced a 0.5-1.0mpg reduction across the board.
Cornering speeds will be reduced due to the larger and more flexible wall sections. Acceleration and stopping distance might take a small hit, but it's not a staggering change.
Overall, I loved them. They did quite well off-road and were amazing in snow and deep snow.
Enfield, do you have a rod lift on yours or do you have it at stock height? Thanks.
No lift. It is completely stock except that I put the KO2s on it. There is NO rubbing whatsoever even when in access mode. The tires are 275/55/20.
Make sure you keep in mind that the diameter is slightly larger than the stock tires. That is important to remember if you use a spare. It also throws your speedometer off by 2-3kph at 100kph.
2015 Range Rover Sport SCV8 HSE Dynamic
@enfield After +- 2 years, how are the BFGs doing?
any issues when accelerating/braking hard?
I forgot to ask - would 275/60 be advisable or not?
Sent from my G8441 using Tapatalk
The BFG's are doing great. Took 'em to MOAB last year. I'm 35,000km in. They, also, did great last year in the snow.
thanks, do you think the 275/60 will rub?
This is a cool picture. Planning on changing my stock 20s to these BFGs. My rims are silver though.
You seem to have sprayed your black or its a stock?
I had them powder coated. Holding up well after 4 years. The ice traction on my BFG's went downhill at around 50,000 km. Plenty of meat left on them for the summer, autumn, and spring. I will now run winter tires on the 21 inch rims that came with the car during the winter season.
I've got a set of K02s on stock 20's. I only run them in the winter or when I going off road. I like them but they feel heavy, a bit sluggish and gas milage suffers. Because of that I run the stock 21 road tires the majority of the time. Before you go K02 take a look at Cooper. I was reading on another thread they have an ATS model that is 10lbs lighter per tire than a K02.
Nice. How much does powder coating cost on avg?
So, you did not have any rubbing etc issue on your BFGs? 50K miles and still some left wow. I am concerned that I would have a bad performance in the winter on them.. so I have chicken out and decided to replace with all season 275/40R20 Perelli Scorpion Zero A/S Plus, they are only $205 with valves. I probably will buy BFG or similar with another set on rims once I move the car up north.
Thanks for feedback. I have decided not to get beefy ones for now. Going with stock size.
1 - 18 of 18 Posts
