Just threw a set of 265/65r18 BFG All Terrains on her today. No modifications necessary except for removing the front mud flaps. It drives great and fills out the wheel wells nicely... I would highly recommend if you're in the market for new tires or looking to upgrade.
Any rubbing when at full lock or articulating?
This is a really old thread from guy with only 8 posts. He is probably gone. I run 265-65-18s on mine, they do rub the radius arm at full lock, but not terribly. They will rub in the front wheelwells at full articulation, and on the fenderliners in the rear. If you are still on air toss some 2x4 pieces in your tool bag in case it hard faults, use as spacers for the bumpstops, and you should be fine.
I ran mine at stock heights with 265-65-18's and they were fine, other than rubbing noted above. They look more proportional though with a 2" increase in all heights.
I've got them and honestly it only rubs when hitting bumps at ~70% lock. Great tire size
