Hello,
while I discovered, what part ist NOT fitted in a SE Spec P38 I need help identifying the "crimps" in two connectors, as I want to use the plugs and patches, which are close to the full spec variants.
The Connectors in question are C323 (12 possible wires) at the BECM and C305 (6 way). Can You help me how these electrical connectors inside the plugs are named technically for ordering them?
Being lazy, I want to fit the connections into the genuine plugs and follow the original routing. There is just a small part of missing, the connector in the door is in the loom, but there is no connection to the BECM. The place is empty ;-)
BTW I have fitted rear puddle lights, while I had the doorcards of, for disconnecting superlock. Left side, plug and play, right side ... no light. After I made sure the "door open" signal is transmitted to the BECM I wanted to test continuity, identified the plug in the ETM and imagine my face, when I discovered that there is simply no wire / connection to the BECM for the right side ;-)
Position 6 in the plug is blank, but there is a connector at the BECM (male).
Thanks in advance
KCR
Thanks in advance
KCR
