Ok, so I'm moving on to some seat memory issues in my 2004 HSE and first thing I did was to see how the BCU is configured, using RSW Solutions All Comm product. The software works properly for the engine ECU, so I'm assuming there's something wrong with the BCU or its wiring.
My seat memory doesn't work, but all other functions seem normal if invoked manually (no memory).
Has anyone else experienced this and how did you correct it?
It's going to be almost 60* F today here on Long Island NY, so I'm diving in today to try and troubleshoot the problem.
If your RSU is working fine for the other systems then it would not be the issue. Have you already inspected wiring and connector at the BCU? I don;t remember if the first gen have a separate seat ECU. Have you checked RAVE?
